with Italian autocad does not work, I made a small modification here:
http://www.cad3d.it/forum1/showthread.php?t=14033Look, there is also a very banal solution, that of creating a script.
in excel, create a column with a formula
=concatena(a2;",";b2;";c2;"""
where a2 and b2 are the coordinates and c2 the circle radius.
just copy the column with the formula in the note block and enter the _circle command at the beginning of the text with the coordinates. then you have to save the .scr file extension and drag it to autocad. and automatically you will have all your beautiful circles.
longer to explain it than to do it.
