dynamic block creating series
  • Thread starter Thread starter caster79
caster79
I wanted to make a dynamic block of a radiator that sets me the various elements. assigning linear parameter and then the serial action I can do this, but I would like to be able to change it according to the amount (n. of elements) and not according to the length!
you could use the visibility parameter and set for each state an increasing number of elements
It might well be a solution but it seems very strange that there is no possibility for use of this type!especially it is an action that reproduces for a block what should be the serial command!even xè with the linear command is manageable the thing, with the only uncomfortableness of having to count from time to time the elements!
Have you tried "dynamic control"?
to use the block you would have the option to choose the number of items by selecting between preset values (1 elem., 2 elem., ...). Obviously if you need a number of items other than the prefixed ones you should set the overall length (and not the number of items) as you have done so far.
pilasters
