antonio.sab
I should create a gearbox which consists, in a synthetic way, of two trees supported both on one side by a radial ball bearing and on the other by a pair of x-shaped oblique ball bearings (see attached photo). I had already designed to dimensional the duration of bearings, however, considering skf bearings, however for lead time reasons, I was forced to opt for other suppliers, (grw). skf tells me that, for the pair of x-shaped bearings, the dynamic load coefficient is equal to 1.62* of the single bearing, while the static one is equal to 2 times that of the single bearing. considering the bearings of the grw I cannot find similar information to proceed to calculation of the duration of the above bearings. I initially thought I could use the same intake, but the grw bearings proposed have a contact angle of 15°, unlike the skf bearings for which it is between 25-40°. Can someone please tell me how to adjust for the choice of coefficients c and c0 regarding the problem described above?
cordial greetings
antonio corbo
cordial greetings
antonio corbo
