errore con autocad 2009: unhandled access violation writing
davide510
hi to all my name is davide autocad use recently, for autocad accuracy 2009 on windows view and I found a problem that I can not solve, autocad gives me an error about every 10 minutes of use, the error in question is this: unhandled access violation writing 0xdbf2000 exception at 772f9b2bh .
I already tried to uninstall it and reinstall it but without results someone can help me perfavo :confused: :confused:
errors like this are usually due to software that conflict with autocad (antiviruses for example).
first install autocad upgrade. then try to disable one to any "invasive" programs (as I said before, any security tools that are active).
look for example what causes that error in 2010 on windows 7:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkid=9240817&id=14857710&siteid=123112here instead in the case of reading, and not writing as in your case, a virus is hypothesized as well:
http://www.cadforum.cz/cadforum_en/qaid.asp?tip=3340this to make you understand the variety of problems.
Thank you so much I'll try to do this and I'll let you know if you have any other advice I'm happy to hear you soon:
only one last question could you give me advice on how to disable security programs and tools to make
ah ok understood I hope it works now I make attempts and I let you know thank you very much you were kind
