errore in messa in tavola nx 8.5 given object does not have the required csys matrix
Unas
I have recently passed from nx6 to nx8.5, it is a few days that I am preparing the table of a component, at some point after a global update of the 2d I remain some unregistered views and I appear this message
view update
view name: front@7
view type:
error: given object does not have the required csys matrix.
I don't understand what I may have done wrong than what I did before in nx6, I tried to redeem visible all levels (including component csys) but nothing.
I made the table again from scratch but I arrived at the same shocking result, a put in the table that does not update completely!
Have you ever happened?
Hi, this kind of mistake I've never seen.
try to do these two operations on the component (not on the table): analysis geometry and see if it gives you some mistakes, then try to make a refile of the part.
Let me know. Hi.
Let me know. Hi.
thanks to the answer, but unfortunately no has changed nothing, the model then is also quite simple, the only way I found to not make the table angry is not to view level 1 (the solid one) in the views that give problems... the drawback is that those views serve with the solid displayed. ...
I could tell you to post the file if you can, so I'll take a look. do another test in the meantime: put the solid on another layer.
I tried, but nothing... Unfortunately, I cannot post the file is strictly reserved
Maybe I solved (without understanding how) an old backup copy of the table file still works
Has the 3d model exceeded the analysis of geometric texture?
to me sometimes happened on imported iges and then closed to solid with high tolerances.
Now I don't know if the message was the same, but the result didn't change.
to understand the area of the problematic model I cut the view portion to represent until to indentify the problematic area .
the model 3d is native in nx 8.5, I prepared it a couple of days before putting it on the table, one of its peculiarities is to be modeled about 1 meter in z regarding the csys, for the rest it is trivial I made tens like him.
I immediately associated the problem with a particularity that has always nx, when in the table setting you change the scale of a view or the move somehow different from the drag and drop and this as a consequence ends out of the sheet, in the case of the scaling this happens often because the csys of the model is used as a reference for the scaling operations on the table, if for example on a view step from scale 1:1 to 2:1, the view is thrown
but the mistake he gave me is something new, never happened to me and does not allow me to change in any way the view.....
Boh!
