Paola
a greeting to all the visitors of the newsgroup.
I have a workbook with a lot of sheets. in each worksheet there are columns whose sum (vertical) of the values is equal to zero. for print reasons I hide the columns at sum nothing; I do this for each sheet I have to print.
is it possible to automate the process with a macro?
the macro should then read the column sum per column (and sheet per sheet) and hide the column if the sum is equal to zero.
a true thanks to those who will help me.
