export design from solidworks to dwg
Piero Guaglio
Good morning to all, I am new in this community and I immediately wanted to ask you this question:
I made a table of a pretty heavy design. finished the table I try to make the dwg (as every time) and gives me: error on the views 1 - 2 - 3 etc...
I tried them all, for example to put the quality draft, to make a view at a time and to turn it into dwg (still error), to put the quality to the minimum from the settings.
Is it possible that since the design is too heavy it gives me error of the views and cannot process the dwg?
for the dwg we use draftsight, not just the maximum of life for the 2d.
Thank you so much, guys! !
try exporting views on different sheets.
just to see if you sort something out.. .
I tried, it gives me the same mistake on individual views. in particular I did so:
put into the table, single views saved in dwg (and then I had thought to recompose everything on 2d)
Some views keep me good, such as details, views projected no.
I don't know if I explained well. .
Thanks anyway!
to me never even happened with slddrw file of 30-40 mb. try to turn it into dxf
part or together? views with hidden lines or without? If you make a new design with a single view still does it? Do you have levels? Can you make a screenshoot of export options?
I don't know why they doubled ahah.
However it is a set, it has hidden lines and it is all on a level. I don't want it to be a table problem. .
the problem also gives me a new design with a single view. .
good morning the same problem we have on several stations in the company where I work, I could notice that on the big axiemi solidworks automatically sets the quality draft of the view and even if you try to bring back the view in high quality the system immediately reports it to draft.
if some good soul has some solution I would be very grateful.
i thank you for your concern, but i have to try to solve the problem permanently. thank you.
thanks for the information! i tried to make the dwg in high quality but it really puts a life, almost 4 hours (a set consisting of more 65 mb machines!
good morning piero, in some cases it does so to me (and it is not normal), i think that the basic problem is however an incorrect conversion of files (for example i have recently passed to 2014 while i was coming from 2009), the fact is that at this point i do not know how to set the whole archive in high quality, because the drawing views can not be transformed if even the assemblies and all its parts are not in high quality.
