Iacopo3D
I am facing a problem: through solid edge (st4) I would like to export dxf profiles created by the views of a 3d model, which will be given "to eat" to the machines in production but I can not export a file that is compatible. with the old cad 2d that was used for the same operations (gbg), it turns out that the segments receive as properties a different number each and the machine would want them in order at least consecutive from the base of the profile to its final point. with gbg you can get an order but with the only if I do not find a way to give it.
I tried to create different 3d models by changing the order of features or by creating the profile of revolution (which I would like to avoid) but the result is not in order. .
help?
help?
