first steps with revit - problem levels floor plants
  • Thread starter Thread starter duken
duken
I started a project of a villa (explained in a video course) and opened the first file where there were only the lines to follow to create the walls.
in the submenu "floors" there was:0-ground floor
1st floor
planimetry
in the tutorial I saw that they had created multiple levels and also renamed:1-plant pt
2-first level
3-second level
5-third level
6-covering 2
cover1
planimetry
then not knowing how to do, I duplicated in my file several times "0-ground floor" and eventually I created and renamed the missing submentu.
Well I created the central vault selected in blue, and the guide says to do:
element-- > height hazard--up to level 5: third level.
If I do so, it appears to me in the bond of height only:
1-plant pt
2-first level
and there are no others..(5-third level,6-covering2...etc)
You explain why?
but you are sure:rolleyes:I did some tests but the levels even if copied and not created with the appropriate command are always usable as basic constraints or height.Be aware however that copying the levels does not automatically create the corresponding plant view. the command to create levels is tab level creates reference group.
have you gone to see in a section or in a prospect the altitudes of the levels?
it would be better to create levels (which then generate plants) from a section or prospectus... .
Maybe I found out why. .
in the prospectus gives me 2 levels:Perhaps I should create from the prospectus the levels and after they will appear also in the element properties. .
I'm asking for another thing. .
from a prospectus I isolated a wall to make a profile to a wall.
finished work, if I click on the icon "hiding/island temporarily"
the option "restore hide/island temporarily" is not selectable. .
and then I can't see the whole project. .
How can I solve this?
Below in the view control bar there is the symbol of a bulb,click on that, then in the drawing area click on the object you have previously hidden, eventually click on the top right element in the group shows hidden elements.
You must have messed up. ..however to delete a prospective view you can click on the name with the dx button and then in the menu that appears to choose delete. then click on the prospectus symbol pops up the fleg of the direction in which you have to restore the prospectus and recreates it.Be aware that the prospectus symbol can be rotated at will. Alternatively, from the view tab click on the prospectus command and insert another one in the location you prefer.
I started 2 days ago and I'm already happy with what I did. .
cmq I recreated the prospect, but this time that wall before I do not see it..in any kind of display. instead it is present in the other prospects.
mystery.
Thank you for your help. very kind.
mystery.
I increased the horizontal crop offset and the wall is displayed correctly.
I also learned this little thing.
I was still trying to figure out how to draw the wall:wink:
I am glad you have solved, breaking the head on things is worth more than 100 answers on a forum:finger:
