fixing (?) solid edge 2d drafting
  • Thread starter Thread starter pironman
pironman
Good morning to all, I downloaded solid edge 2d drafting because I needed a free cad to open and edit dwg at home.
I can't use the move-copy command: the procedure is this:
- select the element
- click on the move command
- type the desired increase
- I press to a point on the component to move
At this point, he moves me... However, it moves it continuously, not with the increment I wanted, and the x and y value boxes remain gray, not selectable.
The strange thing is that this joke is doing it today. yesterday, it worked smoothly.
Any advice?
That's what happens to you because you've got an active grill.
you can disable it via this button (and via keyboard f9)
