flattening views 3d
whatamess
Hello everyone!
I'm new and I did a research about it and I didn't find anything. This is my first rendering done with revit and I noticed a flattening of views in the realistic visualization style, in the sense that you do not understand where a wall begins and where the other begins, where there is a wall later and one more back. both with shadows and sun activated and without. the graphic display options I set are: intensity only 45, indirect light 15, it projects shadows 15. What do I do? What's wrong? :confused: thank you in advance!
provided that even I find enough readable the image tries to activate even the ambient occlusion will make you more evident the darker areas that are located at the corners allowing you to better understand the volumes. You could also try the way of manual exposure and slightly darken the tones.
ps: realistic viewing style is not really a rendering many effects are not in fact calculated.
