flexible/rigid secondary assembly
emanuele grasso
as we well know the command "flexible/rigid secondary aids" is used to bind a part of that product made flexible to another part of another product; My problem is that when I activate the command and I go to bind, the computer becomes an absurd slowness and in addition it goes to me in excess of giving me a tide of errors (which are not there). to obviate to this the constraint of type "undefined" and then automatically puts everything fit giving me the constraints for valid
Is there something wrong?
Is there a setting that allows me to set the offset bond as "undefined" regardless?
there is undefined, identical and opposite
when I put the offset bond is set, of default "identiche"; It's a bit of loading, I'm going overboard, and then if I put the "undefined" system. .
one I would like to understand why it takes so much time and two I would like to understand how to put an offset bond already "not defined" without having to change it every time
for the undefined bond maybe you can set it as admin in the settings.
for the slowness I recommend you cancel the casettings and try again.
Of course, you're backing up first.
how and what to do you find out looking in various posts. He has spoken many times.
let us know about the outcome
not having your catproduct is impossible to understand and help you.
I'll give you an example of what flexible axioms are for. flexible assemblyand if you are looking for the forum there have been other discussions about it.
type this --> qui
as it says rightly victorious, without seeing the product it is difficult to understand why it gives you problems.. .
I'm guessing: If you return the overriding error, it is possible that in the product there are constraints that go into conflict, even if you say that there are no errors (but if you give them to you and with the analysis of constraints you should identify them and correct them).
in the offset the orientation parameter defines whether the selected geometries must be equal or opposite (changeable even with the green arrows that appear) and are the commonly used options.
I therefore believe that if you use the default "identiche", the system gives you error is because the orientation of the offset is incompatible with the other constraints present.
if imposed "undefined" the application calculates the best solution (i.e. it directs the faces according to a criterion not linked to the orientation and the error disappears, but obligations the system to recalculate the solutions (and maybe it is slow for that) my opinion is that it is not the correct way to bind (and in fact "undefined" is so little used to be remembered to fatigue.
type this --> qui
in the film however makes it an independent subaxieme from the original constraints.
what is asked in the first place is to cross the constraints from the subaxieme to another.
just to remember it 😉
@falonef You mean options?
