fold corners on sheet development.
  • Thread starter Thread starter ikki78
ikki78
Good afternoon to all,
I have a question. .
currently on the sheet metal development board the bending angles are described with "on x°" or "down y°" and so far all good. .
our requirement is that if example a fold is described "on 45°" in the sheet metal development board is "on 135°" which is nothing but the angle that I should do in dieping calculated as 180°-45°.
Can someone help me??? where is this configuration file located? ? .
Have a good day!
I searched for this file for a while and did not find it (also interested in me this solution, when bending the sheet, for those who work is better the inner corner), and also to change the text from English to Italian.
if you right-click on a table 2d ->options/properties -> properties document -> table -> development sheet.
at this point you can define the writing and the line type.
I tried this but I did not remain in all the tables perhaps I mistaken the procedure but after having made my sheet I create model table and the writings and the lines always remain in English if instead I make a table not tied to the model they see me as set.
I don't know what to do.
$q{bl_ang_rad:f(%.0f)="}<fdeg> Down
This is the string that comes out you have to find the file where you point and change it, I did alcone tests and I saw that changing the 0 before the f, according to the number you put from the decimals of the corner</fdeg>
