MirkoAntonello
good morning, use intellicad of primus cad (which is a photocopy of autocad). I have a problem to solve. I'll explain. I create an associative restraint on a closed polyline (or a rectangle) and everything works: Iron or rearrange the contours and restraint follows the perimeter that "contains it". if I cover the restraint and the polyline, the copied hold remains associative and everything works well.
But if I move the restraint and the polyline, after moving the restraint always loses its associative property. Therefore, if ironing or shaving corners, the restraint remains firm and does not adapt to the new polygon. I am forced to manually place it from the property table (and it does not always work), or, delete it and do it again:-(
What can I do to maintain the same tenure association properties when I use the "setting" command?
Is there any flags to activate? or system variable?
Thank you all.
Thank you all.
