function ''save bodies'' or ''divid''' and sheets
  • Thread starter Thread starter onizuka
onizuka
hi, usually when I put on the table a welded assembly of sheet, first of course I create the body, I make the board of the assemblies and of the welds, and I put in queue all the tables of the individual welded that compose it, to do this and to have also a distinct materials in the first sheet, usually ''scompongo'' the body with or ''save the bodies', but I do lose them all
How can I do that?
thanks in advance
sure to use the right terms?
a set cannot be decomposed in bodies. a multibody part yes. What are you talking about?
a distinct material is used in the axiemi, in the details a separate cut is used.
if you work correctly you do not need to do any Slave body nor, above all, divide.
made your part multibody with its distinct cut after which you can work in multiple ways:
-extrapolate each body by becoming a unique file (but connected to the father) by doing insert into the new part on the body concerned; this part may or may not be connected to the properties of the separate cut. the plates, however, must be remade but you can add functions to change it if you need to make a pre-work drawing
-doing the table after selecting the part click on body select. maintains all the features of the part from which it is taken and maintains sheet development. of course if there is no specific configuration the body is the final one and if it is necessary to add pre-work overmetal it is not possible
I misformed saying ''assieme', however, I have always done my multibody part, like welded sheets or other, and in the end I have always done or split or save bodies, but saving some corpses of sheet does not keep me the functions of the same.
I didn't understand what you wrote
if you do a multibody doesn't make sense to make divids (unless you mean something different from function of envy)saves bodies e insert into the new part should get the same result. in both cases only the body is extrapolated without functions and you have to remake or develop the sheet
a little vague as an indication
In fact, I'm talking about saving bodies, what doesn't come back to me after having extrapolated the body, that some bodies created in sheet metal, once extrapolated, can't reconvert them, since it would serve me for developments. above all the ''flat recetition'' that if I can't convert it into sheet does not appear to me. and it happens to me with bodies created by conical surfaces.
once extrapolated loses the characteristic of sheet metal and quind you have to remake the peeling function.
If it gives you a mistake you need to clarify better what and maybe post an image or even better a body.
because if you keep saying don't develop it without adding details and how to call the mechanic and tell him <non cosa="" faccio?="" la="" macchina.="" parte="" ti=""></non>
I attach the zip file with inside the body generated by the body saver, which I cannot turn into sheet metal. we accept suggestions on how to operate.
I use solidworks 2016
https://drive.google.com/open?id=0b6szokf4-rdvywrkq1riug1kejq
Why don't you attach files like everyone with the appropriate mode?
I don't have a google account, nor am I supposed to have it, and you shouldn't assume everyone has it. so I don't do anything with that link
go to advanced mode in the message and post the zipped file
the body develops correctly.
do not use the command trasforma in lamiere ma insert folds and select a board.
