gtemp
Good morning to all,
I need your help.
I have a 24 vdc engine of 800 w power that moves a door through a screw-magnet system.
in the absence of power, I must use a dynamo that directly feeds this engine.
as dynamo I thought I would use an epicycloidal motor always at 24 vdc, on whose tree, I will connect a handwheel.
my question is, in order to be able to carry the gear motor (300 rpm) do I have to utlize for dynamo an engine of the same power?
or can I use a motor with a lower power?
available for clarification.
thanks in advance for the help.
I need your help.
