geographical coordinate extraction
  • Thread starter Thread starter Alessia_Ocem
Alessia_Ocem
a greeting to all,
I hope I have centered the right section for this discussion, it is the first time I write.
problem: extraction in table or excel files of geographical coordinates.
work with autodesk mechanical. I put in a drawing a " geographical position" and other points of "contrasponding position" giving these points a name. passing over the signs I see latitude and longitude. I would need to export these coordinates to an external file with related points names. with dataextraction latitude and longitude data are not extracted.
Thank you for your help,
alessia
with autocad 'vanilla' does not solve. autocad doesn't even know where latitude and longitude are at home. map 3d or autodesk civil 3d
