guide ingresso
ironlomo
I'll be right there.
we designed a new filler input consisting of a series of curves thickness 10mm stainless steel 304.
These curves we usually cut them to the laser, then once they are worked (holes, alesations and balls) we have to put them under the press and straighten them one by one, practically bend, they are bombed, almost certainly due to the internal tensions of the sheet that after the cutting process deform the curve.
My question was... Is it possible to have sheet metal that I know, detained or treated in some way so that it does not deform so much?
if you also know some site of producers. . . !
Thank you all!
