slashzakk
Hello everyone!! !
I write you because they are in the most total drama.
I have to create a movement with parts imported by inventor.
I have a lever routing at one point, moving drives the arm connected to itself through a pin; Finally, the latter, moving, drives a beam that translates horizontally of one meter.
I used the "select and link" command to connect these elements, I inserted all the measures that I needed for handling but when they operate the whole lever does not remain fixed at its point and also translates it.
How do I keep the lever fixed at the point of rotation?
If there's another way to move everything?
Thank you in advance!:biggrin::biggrin:
