Silente24
I hope you can help me. I have a piece of a very complicated frame to analyze, I put all forces agents and constraints where the frame is framed to the rest of the structure. when I go to do the analysis in nastran (I have 2010) reports the following erroe:
user fatal message 9050 (sekrrs)
^^ run ended two to overdose pivot ratios in matrix kll.
^^^ user action: constrain mechanisms with spci or suporti entries or specify param,bailout,-1 to
continue the run with mechanisms.
I know it's a problem of constraints, but I can't solve it, can someone give me a tip? ?
when I put a constraint, on the design to draw the bond with numbers next to it, are those degrees of freedom that has the point or are the degrees of freedom examined?
another thing, since patran 2010 I can't start nastran 2010, which executive file of nastran I have to link to with the configuration utility of patran 2010 and to what voice?
thanks in advance for the help! !
