high performance transmissions, simple to mount
Status
Not open for further replies.
newscad3d
Safe sizing, extremely low encumbrance thrusts, and great ease of assembly: here are the main advantages of sistemi lineari hpls high performance products from wittenstein alpha.[TABLE="width: 780"][TR][TD]on any type of machine tool i sistemi lineari high performance (hpls) garantiscono positioning accuracy, rigidity (game below 1 arcmin), power density and considerable progress force (more than 112,400 n) because they integrate optimally reducer, pinion and rack.
thanks to the extraordinary performance of the whole system it is possible to employ lower size components, obtaining equal or even greater performance. the possibility of downsizing results in greater compactness and economically more advantageous solutions.[/TD][TD]
[/TD][/TR][/TABLE]the installation is quick, thanks to its special geometry and the interface with 8 holes. the choice of the mounting position is free and the adjusted driving edges of the reducer flange act as a guide to avoid the rotation of the system during assembly and side plane of reaction to the torque during use. result: assembly times reduced to 80%, guaranteeing maximum reliability.
on the exit side can be mounted sprockets from module 3 to module 8, with different number of teeth and holes in the socket, integrated in the flange, allow an easy application of the reducer with pinion mounted on the rack.
6 sizes, reduction ratios from i=4 to i=220, available also in angular version and with integrated motor, for example, to accelerate a mass of 300 kg to 360 m/min in 0.3 seconds, with a positioning accuracy of 5 μm.
discover all the details of sistemi lineari hpls high performance.
come to visit us at bimu fieramilano – pad. 11 / stand g47wittenstein spa – tel 02-24.13.57-1 / www.wittenstein.it
Status
