Pierluigi_26
Hello.
are pierluigi, I would need information about the norms on the ball (or bubble).
In particular, I would like to know if it was correct to indicate the number of the component to all the components present in the axieme, even if they are used several times (for example: screws, washers or parts that are used more than once).
attached an example of my case, is it correct or should I change something?
