how to connect nodes mesh more solid
  • Thread starter Thread starter riccardoorru
riccardoorru
Good morning, I'm a student with ansys 18.1 for thesis work.
I can't connect more solid knots despite creating connections, and I can't connect beam and solid knots.
I hope you could help me with a little advice, thank you in advance
hi, you solved?I also have the same problem..to match the knots of different shell elements and between beam and shell...I tried contact mesh, contact node etc.. but it comes a casino..if you solved you could give me some info?
hi! through the share command you find within spaceclaim you can perfectly connect the knots of solids that match each other. Unlike to connect beam with beam, solids with beam and shell with beam, I simply managed through connections. even if this leads the knots not to match perfectly, do not worry because in the final calculation everything is connected because the program uses the mpc. all this do not take it for just 100% and if you discover some more specific function let me know. Thank you very much
