Pasquale B.
Hello.
I made a 2d design on solidworks of some components previously made in 3d.
to do this I chose a sheet a3 (iso), which already contains a tabellina in the lower right, in which you can insert the "title", the "n.disegno", the "material", the "scale",...etc.
The problem is that I can't put anything into it!
Could you explain the procedure to fill out this tab? can you also delete some cell you don't need?
Thank you in advance!
