how to perform a fold of a sheet
Antonio1993
Hello everyone, I am using autocad 3d and I need your help.
I designed a 2d sheet and with the command presses and drags I extruded the sheet for its thickness with the respective fold lines. to this
I want to know. which command can I use to fold the sheet? on autocad?
...to questo
point vorrei sapere. che command posso usae per piegare lamiera? su autocad?
ahahahah!!! Is that a joke?
Forget it, autocad has no command to fold the sheets. in the profile you say you know how to use inventor; use that for these crafts
inventor just installed it. what command do I recommend to perform the fold on inventor?
specific commands for the management of sheet metals.
If you've never used it start from tutorials and go to help... point blank ask these tips on a forum, without even the software's abc (anywhere it is) you don't wield a spider from the hole
