how to set an adiabatic surface?
  • Thread starter Thread starter Sylnet
Sylnet
Hello everyone, I hope someone can help me with this little problem in fluent. I am simulating heat exchange along a conduit, inside this conduit flows a hot fluid, air to be more accurate. the duct is divided into three parts. a central section where there is thermal exchange outside. the two sections at the extremes should not exchange heat, so I have to set a condition that imposes a heat flow equal to zero. I just don't know how to set it up. if I activate the energy equation in models and then in boundary condition under thermal I left the flow with the default value, i.e. 0. the problem is that if I leave zero the program still calculates the heat exchange!
I hope I've been clear enough
greetings sylnet
