how to set the print
luciafor
Good morning, I just signed up. I'm a neophyte.
This is the question. in the autocad model space I designed the organization of a table that must contain more designs.
practically the printing will happen on a sheet a0 so I made a rectangle of 1189x841 and I continued to divide the sheet using measures in mm.
the problem that is rising to me is that in different sections of this a0 will go different designs in different scales ( 1:100 / 1:50 / 1:5 )
How do I keep drawing? :confused: :confused:
for example:
line of 1 m and 25 cm. for scale at 1:100 do: 125cm/100=1,25cm and then type 12.5mm?
the same thing for the scale to 50 and then for a line of 1.25m type 25mm?
will I then simply print 1:1?
in autocad is set "current view annotation scale 1:1"
in space pattern design all 1:1 then in space layout create the windows of the correct ratio. the only thing that changes in the model space is the size of quotas (discale) and texts
the question is that in this table they have to work in 3 and not everyone can manage the layouts. We're all learning now.
a good situation to learn.
an alternative not to make calculations and you want to scare it is to draw all 1:1 and once decided the factor of scale to scale all the interested entities of that factor (even better to create a block and scale it, in this way in case of change of factor of scale the operation is very fast
