html record
Leonardo Poma
I found on a site of explosions where passing the mouse on the parts highlight the name of the part, the code even the price etc. Does anyone know if there is a solidworks plugin (or other) that allows to export the assembly, in a format compatible with the web, so that the information of the individual parts remains to have a result like the one described above or similar?
I wish you good work
and why do not attach the link to the site that so speaks the same language instead of going forward strength of: it could be, maybe they did, the cartomante told me...
if there is something concrete we use it
I said a cow, sorry...
However perhaps the explosive is done with solid (where did you read it?), but the ball does not seem to me and for the notes there will certainly exist software that selected an area insert metadata
as it tells you above massive there is software in fact the link we mention is an example of how that software works.
If you go back to the main town, they tell you what those gentlemen do.
http://topgrafnew.partiricambio.it/default.html
it can also be done with solidworks composed, the layout is a little different but the functional result is identical. the prices you can already have them in the cad metadata or you can add them directly in composer, it is indifferent. see the link below:
https://www.youtube.com/watch?v=dxkfgknurok
ciao
