i can't climb in archicad 13
  • Thread starter Thread starter Ego
Ego
hello to all, I can't scale the design I made in real scale in archicad.
I realized the drawing in scale 1:1, then I clicked on design choice > design manager > settings... > attributes and I set scale 1:50.
then in document > scale drawing plant I set the plant to 1:50.
only that I always see the dimensions of the drawing at 1:1.
I would also like to ask for a small information: I usually carry the pdf of the plant and I open it in illustrator and then I will dress up the drawing to please, you know if there is a more precise and fast method to export the technical design in the right format?
I did not understand the first problem: the quotas did not resize, or you wanted that instead of the real measure, they gave the fictitious one of the scaling (1 meter 1:1 is 1 meter even if the scale becomes 1:2, it is not that it becomes 0.50...)
to export to illustrator, you can safely save in pdf and then open it in illustrator. when saved in pdf, everything remains in scale
to get drawings in different scales you have to go on edita>modifica>resize. at this point you can do it automatically by choosing % (make tests to see if the measurement at the corresponding scale is the right one) or manually (e.g. if the length of your wall is 50 m and you want to get the 1:50 scale you draw a line that is double value, and you align your wall to the drawn line)
but so change the actual size of the object that steps, you do not get a drawing in scale. although probably (though he wanted the odds to change) he did not want a different scale, but a different dimension
I think that's what he needed. And anyway a priori you can't print in real scale!!!! Depending on the object you are representing, you have to choose the right scale and Obviously the object must be resized proportionally!
you can't print 1 to 1. but archicad scales everything automatically, including the level of representation, decreasing the lines more increases the scale to avoid the dough. This obviously does not change the quotas, because 1 meter or 1 to 1 or 1 to 100 is always the representation of 1 meter. if instead he wants that 1 meter becomes 1 cm must resize (then obviously he must go out in 1 to 1)
si archicad scales you automatically. ..but scales everything in the archicad sheet in the same way...otherwise you have to resize if there are elements you have to represent with different scales. . .
I think it's okay. ego I understand. .
I also believe that ego has all the necessary information. However, just for completeness if there are elements that go to different scales on the same table, you can use the book of imagination that import the items to the desired scales
Yes, I don't know you, but I read the list of programs you use (which in vain tried to force me to use... I mean, apart from my famous autocad hate, but if one uses archicad, what's the use of siscam to straighten the photos? )
I also understood that you were of edile-archit but I thought 3rd year... I 5th and a half... and I think you know me
