import 3d from google earth
  • Thread starter Thread starter blue.cat
blue.cat
Hello everyone!
I should prepare an elaborate for a thesis and would be extremely useful for me to be able to import in 3ds max (or even in other formats) 3d modeling with relative textures that is generated automatically by google earth.
I searched a lot on the internet but found nothing recently, what I would like to get is what a user (a certain ruggero77 ) shows with pictures in this post of 2010 on another 3d modeling forum:
http://www.treddi.com/forum/topic/79441-google-earth-to-dwg/is not explained in any way how he got that result, and however the post is six years old.
the only processes found on the net relate to the imports of models of buildings that also cover 3d warehouses, not 3d autogenerate.
I don't know if this is possible, but if any of you did it, could you please help me?
Thank you all! !
Thank you all! !
There is a program called 3dvia printscreen, which is a free software from the dassault systemes.
here is the link from where to download http://dassault-systemes-3dvia-printscreen.software.informer.com/download/you configure any key like hotkey (f10 already set by default) and when you press it all that 3d is on the screen is saved in a file.
the only problem is that save mesh in 3dxml format, so you will need a cad that can read that format, or a converter that turns it into a file that the cad you use is able to import.
This is a link from where you can download the dassault 3dxml player or other free utilities.http://www.3ds.com/products-services/3d-xml/1I think sketchup can import it directly, but I'm not sure. certainly being a cad of the dassault
I tried to install the program but it doesn't work, I think there is some problem because at the end of the installation the window does not open with the contents of the software folder.
the program starts but when I press the catch button nothing happens.
as operating system I have windows 8.1 to 64 bits, I have no idea what can depend on the problem.. .
Anyway thank you for the advice!
If I can solve the problem, I'll let you know!
If the installation went well:
In the command bar at the bottom of the screen you should add a 3dvia prg icon, from which you can configure the folder where the files are saved.
when you press the button (what you chose as hotkey) at the bottom of the right side of the screen should appear a mini window that warns you
that 3dvia is saving the file in the chosen folder.
ps: in case it does not work try to set google earth so that you use direct x instead of opengl
I tried to reinstall the program a couple of times, to make the icon appear in the command bar I had to start it manually from start.
google earth gave error at startup and closed several times, but at the fifth attempt it worked.
place the source that I should export and preview the result, surely I wrong something.
google earth was already set with direct x.
google earth source:
https://www.dropbox.com/s/upze1c86d8sq27u/2016-05-25 10_48_44-visita guidata.jpg? ♪anteprima:
https://www.dropbox.com/s/j9cn935q1ncjo3l/2016-05-25 10_49_03-3d xml player - [1].jpg?dl=0
Mah? Does it matter where on 3d max? other point file type 3dxml does not exist ifmmai *.xml
extension that allows 3d max to import. . .qualsiasi 3d.. the big problem has been ripper that only works until 3d max 9... or 11,... now active the procedure but we are in 2018 have passed two years maybe what you wrote is archaeology...but I am sure today if the procedure is useful also in 2018...
phase 1 I installed the program but it has already disappeared. .not appears in the newly installed program bar. .
phase 2 : research of the program : found is called : 3dvia_printscreen_setup_2.3 and presumed to be dated 2018. .
phase 3 : apro googe earth ( already open from before ) in the center of Milan is the version :
google earth pro
7.1.8.3036 (32-bit)
Phase4: type f10: is a small trivial shed with other industrial sheds around with some houses. .
in a suburban area of Milan... after typing f10, nothing happens but try to enter
in the interface 3d max 17 m here are the following probvlemi
1) the program does not respond.. I have to close it or restart it. .
2) I reopen and in import: in import there is nothing. .
3)moral? Missed or wrong instructions... I write another message when I was able to perform the correct operations that in this post are absent
google earth pro
7.1.8.3036 (32-bit)
from 16 is already passing half an hour nothing in fact. .
4) I look for the rpogram in the bar: It's not there! .
5)I look for the program in the directrori, the pc in the meantime slows down by 50%. .
6) nothing to do with the program there is no draw I try to reinstall it
7) tells me that it is installed
8) I look for the program but I can't find it
9) In the meantime 40 minutes have passed (a madness in 2018 losing all time )
10) start utomatic research takes too long
11) within the directory to search for the program I do not find it
12) I go to the control panel
13) within "programs and features"
14) type the right button to search where it is but it is not possible
15) I make an automatic recurr... typing dassault. employs troop time
16) I search it in the bar
17) I finally find it under dassault but the program does not have that name. .
18) the start ..place the results of f10 on desktop
19) within google earth pro
20) active the 3d screen of the shed in the south milan suburbs
21) type f10
22) within 3d max 17
21) I try to import going on desktop
22) xml selections from import module
23) result: nothing is absolutely nothing. .
lost time behind wrong or incomplete instructions 50 minutes.. .
and not only ... you are forced to return to enter the post again..
2 try. .
reboot google earth...
1) the program stops and closes
2) second attempt to reboot..the google earth program continues to freeze
3) question but maybe insert the version? the pro version? not pro version? What verse?
4) another attempt..Finating the program opens...but it has already passed an hour and a quarter...
5) I go on an easy area (million center) 3d duomo banale texture
6) a dart is saying that it is saving a 3d xml format... is taking time
7) as if I had other time to lose asks me to install https://www.3ds.com/products-services/3d-xml/download8) start to download it is a huge file. .
9) Meanwhile I look for the fiel in the directory.. There's nothing
10) install 3dxmlplayer
11) takes too long to install a simple program
12) and go on in useless things here the result I attach the file in the directory repeat there is nothing1523201002020.webp13) retype f10: nothing happens absolutely nothing
14) my question is...but we will manage one day to make sure google is capable of
recognize incompetence? so avoid occupying search engines unnecessarily? 1523201184936.webp
