import a file mesh da fluent in gambit
  • Thread starter Thread starter Arma
Arma
hello to all...I created at first a mesh rada in gambit then I exported it and imported into fluent and then further stuck through adapt... Now I want to control it in the gambit... What kind of file do I have to export from fluent and then import it into gambit (let's say that it is the inverse process of the usual questions :-) ?ciao and thanks
hi if the file is saved as *.msh there should be no problems overtaking the import --> mesh command and entering the path where you have the msh file .. try
Hello... thank you for answering... no file is a *.cas I wanted to do the reverse process from fluent to gambit... Hi.
therefore the *.cas is not + a cad file (and therefore does not have + an explicit geometry)
in the sense that it is the result of the processing boundary conditions and how much more fluent brings to the file cad .. but you lost the original *.msh file or gave it "in meal " to fluent and then you optimized something?
