import cartilage
Error404
hi to all, after creating hundreds of tables (not to say thousands) my boss made me revolutionize the cart.
now it is completely different and told me to update all the boards with the new cartilage.
Should I remake all the boards from scratch or is there a way to only import the cartilage from the new template?
Give me good news and tomorrow you will see me on the necrology:mixed:
There is a utility in the inventor sdk that is called "batch update style", I think that you update the resources of the designs so if your template is updated "you should" be able to update it in a simple way. If the new cartouche has the same name as the old man, I think it's going to be fine. However you have to try... However to the worst you have to make a copy & paste of the new cartiglio in every table, delete the old and insert the new one, a nice bump but you don't have to remake everything, if this is the question (if the cartiglio "fish" the data from the model obviously, if it is compiled by hand you have found a holy Friday from true Lent!)
Yes, there is the possibility to change the cartilage automatically
windows start, autodesk, inventor 201x
select "guided procedure.... .cartigli1.webpcartigli2.webpSelect the .idw or .dwg file contain the nuvo cartigliocartigli3.webpselect what to copy.... files, borders, symbols etc...cartigli4.webpselect the files in which to replace the foldercartigli5.webpif you created the new cartilage with the same name as the old... the trick is served since...cartigli6.webpGood job!
I searched the path you told me, but I found only two installation files with different name.
Thanks anyway for the advice, I solved with the guide of matteo.
- - - updated - - - -
select "guided procedure.... .View attachment 46882View attachment 46883Select the .idw or .dwg file contain the nuvo cartiglioView attachment 46884select what to copy.... files, borders, symbols etc...View attachment 46885select the files in which to replace the folderView attachment 46886if you created the new cartilage with the same name as the old... the trick is served since...View attachment 46887Good job!
Thank you very much, this function is phenomenal. You opened me a world. :wink:
I would say you did great, this system, which I didn't know, is great!
