import dwg or dxf cards as block but off scale
  • Thread starter Thread starter camale82
camale82
hi to everyone, I tried to search in the forum but I did not find solutions to my case.
I am creating new sheet formats where I currently entered a sldblk block as a cartilage and works divinely, to do so I did this way:
1: I drew the claw in autocad with all the writings in their place
2: I made ctrl c and ctrl v from cad to sw
3: replaced the texts I needed $prpsheet:. . .
4: created and saved the cartilage block in sldblk format so as to recall it on all the formats I need.
so everything works.
now I want to try to connect the dwg or dxf directly and use it as a cartiglio, better explain, I insert block, point file to the dwg or dxf that interests me, start the flag connects file so that if I change the dwg or dxf format I will update the cartiglio automatically, until here I shoot everything, only problem is that with this procedure the dwg or dxf important steps are off
Any idea why?
thanks in advance
why invec3e that change block does not simply change sheet size?
I do insert block, file point to the dwg or dxf that interests me, point out the flag links file so that if I change the dwg or dxf I update the cartilage automatically
Would you show me where this tick is?
I change sheet format, only that in my sheet format the paper is the block that I described above in sldblk format, I would better connect a dxf or dwg block on the various sheet formats so that if I change the block with autocad this will automatically update on all sheet formats, only that when I insert the dxf or dwg are off scale.
you see flooded.
then let us use correct terms please.
you if you have to pass eda an a3 to a2 do not change the block but the sheet format.
maybe you forgot to say that you insert autocad block and not sldblk file.
which are the units of the sheet format?
then I try to eject, my current configuration with the cartilage block in sldblk works, the sldblk block is inserted on the various sheet sizes slddrt, which are closed to the varying size of the sheet from a4 to a3 etc etc. etc. to get the sldblk file I did copy paste from directly from autocad is everything was pasted with the correct size (as I had already written in the starting post), I want to insert the dwg or dxf block connecting it with the famous check, the units in autocad are mm and those of the mm sheet, scale 1:1 in sw and also in autocad.
apart from how I want to manage the cartiglio, I do not understand why the scale import of the left block to 1 does not matter with the correct size.
and then what does the sldblk file have to do with it?
can you attach the templòate and dxf to insert (clean from sensitive data)?
I solved, I made the paste copy of the cartiglio in a new file starting from a dwt iso of atocad (acadiso.dwt), now also works the dwg block.
