bgplmcad
Good morning to all,
I'm not a designer so I could use incorrect terms (I apologize in advance? ).
I am trying to adopt solid edge 2d drafting as cad to draw in 2d some simple pattern.
importing an existing dwg design the texts are moved to me compared to the original location attach image of example (in the higher image you see that the numbers are no longer in the correct initial position).
I tried to control the character and size of the same both in the source cad (font: arial, size: 3) that in the destination cad solid edge (font: arial, dimension: 3) and look identical.
what seems different is the shape and size of the text field (see figures in the lower part of the attached image).
Would someone help me understand if it is possible to import the design so that it is equal to the open design in the starting cad?
thanks in advance for support.
a greeting
a greeting
