import into the table tolerance centering hole
  • Thread starter Thread starter Byron
Byron
new doubt to which I find clarity:
I am beginning to work with sw2015 (sp3.0) and, if in the "part" environment I create a centering hole to which I apply a tolerance (h7 for example) when I go to put it on the table and I call the caption of this hole does not automatically appear to me the tolerance h7, I have to go to insert it manually. Is that normal or is something wrong? the guide does not help me in this or at least I find no solution.
Is the same to you?
