Bla
Hello, everyone!
are new in this forum and then follow two words of presentation: I have obtained from not long the degree in biomedical engineering and in the short working experience I have been able to interface with creo.
the problem I would like to ask you today is as follows: how to import a dxf file as sketch in a drawing using pro/e.
I try to explain myself better.
the .dxf file that I have available consists of a set of points.
my intention is to generate the drawing of a part (e.g. a.prt) and then from the "sketch" menu of the drawing window use the points from the .dxf file as an entity 2d to overlap to the already present drawing of a.prt.
However if I follow the sketch path > insert > from file system > select file dxf > ok, nothing happens.
I tried to import the same dxf file into a sketcher apart with the intent then to make a copy and paste of the points but again nothing happens.
if instead I try to open the dxf as part, this then turns out to me as an imported feature and then I don't know how to operate.
Does anyone have any suggestions on how to operate? I would be very grateful!
I hope I can soon return the favor!
