impossible to open corrupt dwg file
  • Thread starter Thread starter francesco14
francesco14
save to all, and I take the opportunity to wish you good pasquetta, practically because of a poor uninstallation, I deleted some folders that I had on the pc, including important dwg files of work, I made the recovery of files through the recuva program, and I recovered the dwg files, but at the time of opening them on the cad, you know impossible to tell me the error thank you so much in advance I am desperate I have to do the job I send you also the file maybe you try with some method you know thanks again let me know, still good pasquetta
I don't think there's any solutions. if the file is corrupt there is no way to recover it. but you learned an essential computer lesson: If the files are so important, you do at least 2 backup copies.
Can't you do anything really?, but don't move the contents convert them to some other format?, am I desperate to start from head ?? ??
the only attempt you can do is use the recover command, but in corrupt file situations personally to me never solved anything
to me the file is corrupt, there's no way to open it, as a text editor it looks just "strong". as it is unusable.
I think it's the recuva recovery procedure that didn't work perfectly.
I don't know recuva, I know there are other similar programs, maybe try some other setting, if there are any.
know that with ansys spaceclaim software you can open and edit any file type, it also opens corrupt or damaged files, which usually others fail to open. Do you know him?
is used a lot in the world account thirds, because everyone has your own problem. .
I downloaded the free trial to try and also provided a technician to explain the main commands to start with the test.
I asked expace italia that is in my region.
when a file is deleted from the disk, it is never really deleted, but simply the oprative system communicates to the disk that the space occupied by the deleted file is available.
then any other program that requires space can write in the first space occupied by the file. this also applies when the files are deleted from the trash.
this means that immediate recovery allows you to recover the entire file, which is immaculate and therefore as if nothing happened.
time-distance recovery, allows other programs to overwrite in whole or in part the data of the previous file.
ok to emotionally blame the uninstallation (which however never deletes files and folders created by the user, but only the files that the installation entered, otherwise they would serve the dinstallations), but this also means that the "important" file was important after a nice tot of time.. .
as Tristan said you experienced. from now on you will look where you put the work files, you will make a copy of each tot on an external disk, you will be careful about the uninstallations/installations.
think if (as it happens, it is not such a remote event) it physically broke the hard drive. You didn't lose the file. You lost all the files.
hi the only solution that comes to mind, if you have the active auto save you can recover the last . bak file changes the extension in dwg and if it is not corrupt even that you should view
