impossible to reinstall inventor 2014 trial after interrupting web installation
  • Thread starter Thread starter arzigogolo
arzigogolo
hello to all and good May 1st!
As from title, I was installing the free trial version of inventor 2014 on my home computer from the autodesk site following the installation procedure of the site itself.
Once you choose the program in the language to install, click "install now".
all right here, once you click on the link, asks you whether to run or save the installation file of about 9 mb and then provides with the actual installation.
during the installation process, I had to interrupt it for a sudden commitment when it had already installed the three quarters of the program (only libraries were missing), therefore inventor 2014 and vault were already installed.
Just that, missing an option like "get back in a second time", I had to interrupt it abnormally simply by finishing the process.
Unfortunately, so doing, now every time I repeat the installation procedure, when the program setup screen comes out with the applications to install, it tells me that inventor 2014 is already installed as well as the vault. only libraries have (justly) the check mark because they still have to be installed.
to note, that I had already removed both the vault and all other things that started with "autodesk" from the control brush - "install programs" following the classical procedure, and in fact in the list of programs nothing appeared.
However, knowing that autodesk leaves around a lot of crap, I followed the procedure that I found on their site on how to completely remove autodesk products, which consists in clearing some registry keys and delete the contents of the directory "temp" plus other subfolders scattered for the hard disk.http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=2887771&linkid=9240617I followed step by step the procedure, I restarted the computer and I re-executed the installation procedure and here is the problem: when the inventor installation screen appears to me, by clicking on "install", both inventor 2014 and vault are no longer flagged and the writing next says "product already installed" and it is no longer possible to check them to install them!
I tried them all, but the setup of the program always tells me that they are already installed when they are not really anymore!
in the control panel no longer appears to me any voice relative to autodesk, I followed all the steps of the guide to remove the autodesk products, but nothing to do!
the cursed continues to see programs that are not really there!:36_1_28:
I can't figure out where the hell I'm going to read the setup to tell me they're already installed.
I don't know any more than fish, to reformat sincerely I wouldn't want to, someone can help me?:36_1_4:
thank you all!:smile:
Maybe I solved: looking on the network, I found this explanation in the English forum of autodesk that explains exactly my problem and tools to solve it.http://forums.autodesk.com/t5/autocad-2013-2014-dwg-format/help-problem-in-uninstalling/m-p/3895335in practice I performed the "fix it" program of microsoft, and in fact found me that, despite not being present in the control panel in the installed program tab, however there was still some voice in the registry that prevented the program to install.
I try to reinstall him tomorrow and see if that was the problem, but I think he should go.
I am sure that the author of the question has already solved but I answer for who should seek the solution to the problem as I did today. the solution is simple: aprice ccleaner (updated to the latest version) go into tools -> uninstall and even if it is not installed in programs and you cannot start it you will find it on the list. at this point select it and uninstall it with ccleaner. works with all trial autodesk versions. the thing is due to the fact that in practice the program did not complete the installation but it put all the components of the program in the pc in fact it also turns out in the folder "programs" (in my case there was the whole full folder of autocad 2015). you have to use ccleaner force to uninstall because in the list of programs that is located in the control panel it was not me. At least I did. I hope it works for you too. Say hello! :-)
thanks for the excellent solution, I solved the same with fix-it, but if I had known it before even with ccleaner you could succeed the same, maybe I had done before.
However it is just the same thing that makes fix-it of microsoft, it makes you appear in the list of programs to uninstall and allows you to remove it.
It's just like he said, having finished the installation prematurely, the files were copied to the disk, but the program entry in "install/uninstall applications" does not appear, hence the need to resort to escamotage like mine and your solution.
