insert a prefix into attributes with a single selection
kronos
I have a big problem that I think you can solve by changing the macro vba created by shape...
I have a long set of light points numbered through a block having the attribute that contains the number. now I should add to each number only a prefix of the type xx- “existing number”. with the macro shape I can do it but I have cmq to select in order every attribute, which makes me waste a lot of time. I would like to select all attributes and add the prefix to all. thank you very much in particular a shape.
Here comes... .
works as the previous one, select the attribute tag where you have to enter the prefix, type the prefix and confirm.
you can select items individually or with everything or _all so then select only the tag that interests you
Thank you so much shape... works perfectly; You saved me a lot of time, thanks again:-)
ps: since it is the 1st time I use these macros you can illustrate something in + maybe with some links. Thank you.
These macros are written in vba you will find a lot of documentation both in the forum and on the internet, but you will notice that it is a language that is now extinct for the programming of autocad, of the 2010 version is no longer supported, or better you have to install it aside, from now on you will go to the .net other programming language. If you have to learn from 0 I want to do it already with the right foot.
ok thank you very much for the straights....and again thanks x the macro:finger:! Hi.
Sorry kids are new in the community. I have the same problem but with the suffix. Can you help me? Thank you very much in advance
