Massi2809
hi to all, use inventor 2022, I have the need to represent an adhesive label on a curvilinear surface of a set (the bottom of a reservoir), I thought to use the function "balance" in order to be able to see it in the drawing view in .idw file but I have to hook it to the .ipt file of departure, but if I use the melt in another set it takes behind also the embosed label; Would you have any suggestions? Thank you.
