insert an image on the curved surface of a 3d model
la.laura
Hello, I am coloring a frame (so all curved surfaces 3d) and I would like to know if it is possible and how to insert an image on its surface. thanks in advance :smile: ps. are the first weapons with solid edge...
there are various methods on how you can get the result.
the easiest is to create a face style with the image inserted as a texture and then apply it to the frame.
the problem is that the image will be repeated on the entire surface depending on the size set.
the idea seems effective to me for the result I have to get! exactly how do I do to create this face style by inserting the image as a texture? step xd (work with st8)
