insert custom templates
  • Thread starter Thread starter deep70
deep70
Hello everyone,
I apologize if I ask, but this is an operation that I have done a while ago concerning the putting into the table, in essence I have a client who rightly asks me to use his own style of quota and then to use his own templates, I no longer remember the method of inserting into solidworks though...
Can you tell me the right way to do that?
thanks as always to everyone for the answers and good day.
Holy crap. You're really ubiquitous. Congratulations! !
thanks and good day to you!
no nothing to do.. We're not here. the style doesn't vary, I certainly did wrong something.
the client's templates file is a .drwdot file extension.
I have made several attempts but without results.
Can anyone tell me the right way? ?
thanks to all for any answers.
that screen just says that you added a new folder, not what is the reason why you don't load the template.
However once you add the address containing the templates you are fine.
when you create a design, part or together you do not need to use the beginner mode, but the advanced one that allows you to have access to all folders instead of default modelsImmagine.webp
but how/where do I add the address? You mean by the procedure I've already done with file placement?
Yes. the window appears if you want to add that folder. but it is already present (last voice)
I honestly don't understand where you find problems and what's wrong with you. It's not like you're trying to explain what your critical points are.
I'll get you a video with the procedure. attention that if you want to change style to a drawing already made the thing is quite different than starting with a new designView attachment aggiunta modelli.zip
That's right. But to me it does not seem that the quotas vary, apart from the fact that I do not see them all the formats of the sheets.
Then let's go.. otherwise I risk madness: :-)
the customer provided me with the following files:
a1.slddrt
a2.slddrt
a3.slddrt
a4.slddrt
then sends me an email with a file telling me that those are quota styles.
the file is:
pse.drwdot.
I would now need the right procedure to make sure that:
I could upload the desired format sent by the customer with the customer's always quote style.
until now the result obtained is that I only see the last of the files mentioned.
Well, here you are, you explain yourself wrong and halfway.
drwdot is the design model where the model options are set
slddrt are sheet formats and upload to the respective voice of file positions
once you create a drawing file you have to appear a window like that attached with all sheet formatsImmagine.webp
Yes, but that window only opens to me if I open the new design from here, and not from the folder I added.
