insert new tebis 4.0 plugins
pablitodane
I'm new to the forum, in the company where I started working you use a lot of tebis software and I'm slowly learning to use it.
I was wondering if you can insert custom constraints into the tebis (maybe via plugin) which will then be automatically set according to the case from the program.
I make an example to explain myself better: in the library of tebis there are all the various tools that are from time to time built and used to program and execute simulations, and for each of them are set processing parameters (e.g. standard processing speed, progress, depth of pass...).
I would like to set (possibly even by building them myself) plugins that allow me to vary these parameters depending on the case: For example, if you are at risk of vibration because the drilling piece is placed on a rather high base, I would like the parameters to be less pushed and then automatically lower the standard parameters by 10%, so as to risk less than there are vibrations.
Is that possible? If yes, in what language should I plan these plugins?
thanks in advance to all for the help.
