Emmeuno
Hello to all of you. I have this need and can't figure out if it's a software limit or I can't find the right commands.
following the online guide (after very difficult sessions - they are self-taught) I managed to set the attributes in a block and then realize a cartiglio where I can insert the design and design descriptions, the sheet number and the max number of sheets of the project.
when I insert another design everything works regularly (the numbering of sheets is updated etc).
I must also insert the numbering of the following sheet, but I can't understand which field is dedicated to this function, as this must also be updated when a sheet is added.
the vba is no longer present, I was wondering if you need to activate an autolips function or a script or I have to give up.
But I had done a good job all by myself.
I hope some of you professionals cross this post and can help me.
thank you in advance and good Christmas to all.
