install autocad 2008 32bit on i5 64bit
  • Thread starter Thread starter Ecathe
Ecathe
Hello, everyone! I have a problem...I would like to install a version of autocad (2008 for precision) with which I was from god, on a pc with processor i5 to 64bit...my problem is that the copy of autocad 2008 in my possession is 32bit and at the time of launch of the installation tells me that it is impossible to install this version of autocad 32bit as the processor is 64bit.
What do I do? Is there some kind of plug-in or solution to my problem?
thank you so much in advance to anyone who answers!
I don't know. Even though the strange thing is that some 32-bit applications quietly run under win7 64.
but mom autodesk has placed a verification already in place of installation, it means that the program expects certain points of support that will find different between 32 and 64 bit.
the solution I found (for a friend's laptop) was downgrading the preinstalled win7 64 with the win7 32 supplied insiame to the laptop on dvd.
because it had only 4gb of rams (which is the 32-bit limit) and had no intention of installing any other, the change was an almost mandatory step.
if you have more than 4gb the speech gets complicated, because with the 32 bit you would run the autocad but you would lose the use of part of the ram
no no pass to 32 is out of discussion! Besides the fact that of gb I have 8 (I will lose half) I have other programs that I have specially taken in the 64bit version... if there is no solution I will continue to use autocad on the old pc... than beard though!
if your pc has 6 ram gigs use it at max 4
for precision, 3.25 gb, but only if windows7 is 32bit.
if instead ecathe has win7 to 64bit, then it will be supported by a minimum of 8 gb of the starter version, up to a maximum of 192 gb of the ultimate.
a way out could be the installation of 32bit autocad in xp_mode environment, but depends on what version of win7 has.
when you bought autocad you certainly received the two supports with x86 and x64 versions... or didn't you buy it? :confused:
I downloaded it free of charge from the site autodesk student Comunity (at the time when the version 2008 had just been released) as I am university student. on the site 2008 there is no more...start since 2010 ahead.. .
You better switch to the new version.
also because I do not know if the student license for 2008 is still renewable.
In fact it is not...I don't understand why if you have the opportunity to install 2011 you dare to want 2008 :frown:
the student license covers all the available software and was extended this year to 36 months overall with possibility of renewal...so it is still valid. the only problem is to recover the r2008...I already have the version 2009 but unfortunately (or fortunately) I use mainly parametric modeling software like revit and allplan and the small amount of operations that I still carry out with autocad is not worth the "fatigue" to look for the commands in the new versions (where they were moved all or almost all)... but if there is no other solution I will follow. Also because I don't want to declassify the new pc to turn a single program!
thank you very much anyway to all for the help, attention and above all the time dedicated to this thread! except to tristan who gave me the thief:wink:(scherzo)
This year it has been extended, from the releases 2011! Who tells you that it is retroactive?? you try to see for scrupulous if you can get a valid code for your 2008 then you can tell us...but I wouldn't put so much hope in you.
except for tristan who gave me thief:wink:( joke)
I have poisoned tooth
Why do I install and use autocad 2006 32bit on win7 64 pro?
the only shortness is to execute it as administrator; at the start "try" to give you an error of incompatibility, but confirming with continue everything starts and works properly.
greetings
Marco:smile:
because autocad 2006 64 bit does not exist!
...for gold... :d
champomthe undersigned has installed a ldt_2005 under win7 pro 64bit, but only and only to 2 conditions:
1] I was logged as a user belonging to the admin group
2] as an installation director, I chose a partition other than that of system.
but the discussion you read or pretended?! Wake up! you can't!
Hahahahahahahahahah! Damn it if you're a bad tristan! Maybe he was wrong to crush and asked the question instead of the answer... or maybe he didn't understand!
However, it was necessary to record, I "refused" to evolution and downloaded the updated version of autocad already to 64bit...
