install two versions
  • Thread starter Thread starter rubo825
rubo825
is it possible to install two different versions of solid edge on the same pc? I explain better, work for two customers using one st2 and one st3. Obviously not at the same time, so I could "disable" one and use the other... but I wouldn't want to continue uninstalling. . Any idea? Thank you.
search for "multiversion" in the archive.
That's right!
only the 32-bit, if you want the 64-bit version no!
if you have the 64 bit you have to use the 32-bit version.
That's right!
What does that mean? that I need to install solid edge at 32bit? both st2 and st3? I installed st2 64bit and st3 64bit. Until today I used the st2 and it worked perfectly, I opened st3 by chance and now st2mi says it is not active! I also tried to use st2 makevercurr.exe but it's not right! help help
means what I said. makevercurr.exe does not work for 64bit.
We said it and laughed.
from st4 works, but only for st4 <-> st3, or higher than st4.
for all precedents the game does not go unless you install the 32 bit.
the only way to be in order to install 2 versions of if, have 2 logical disks or a partitioned disk with 2 mounted operating systems, so that when you use a version of if you can't use the other (source...my assistance).
Moreover even having installed them on the same partition of windows is not that you can use them both.... when you activate one, the other just doesn't work... .
every time I'm amazed how siemens are so perviously convinced that putting sticks between wheels to honest users is a good commercial policy, they learned from solidworks corp. how to manage licenses... :cool:
then they told me that I'm still in revolution....who knows what awaits us.
It will be!
Look, if I have to break up on this then I also eliminate the last license still in service.
to me han always said that you could do, this is what said assistance!
According to them one is so good to use, on the same computer, two versions of himself?
No comment, really!
I decided not to update... and it is 4 licenses!
My clients are all on 20. I upgraded until st2 and never used it!!! 2 years of updates for nothing.
In 3 years I have recovered the value of licenses and maybe I will think about changing software, maybe one that gives me the chance to use the software even on mac.
revolution? just start and don't pay any more updates... we'll see who's going to make the revolution!
It will be!
No comment, really!
I'd say we both have the same assistance if you want to know. I asked yesterday to install st3 and st4, and this is what I was told.
look, in 8 years of if I have called maybe 10 times (mostly for bachi).
the problem does not concern me (I do not have the st3, but only d&d). I stay on 20!!
we unfortunately at work can not stay back with the versions, as being tertis, a little we have to adapt to the customers, but I do not tell you the problems that create us with the development of sheet since we use customized values.
to install multiple versions without having problem just layer windows, I have said it now I don't know how many times but you end up getting back on the usual speeches.
Layer windows is also a much more effective solution than the famous "makevercurr" that has never been a decent thing in my opinion.
if you want to talk for common places the software of the neighbor is increasingly green :)
which software tips for layering and layer management?
I found the svs 2.1 but personal version that is probably not entirely legal for use in a study and also does not turn on w7.
I should be able to use solid edge st3 along with v20 on a 64bit windows7 system
How can I do that?
bye
Maronnnn as I tell you! ! ! ! ! ! !
but not only from bds, even from autodesk must learn!
other than terrorism and cyber intelligence, they are absurd.
