installation update and new version st
  • Thread starter Thread starter libero85
libero85
hello to everyone, I have solid edge with floating license, so installed on the server, now I should update if 20 with cd stv100 and also install the new st, but where do I install it? on the server or computer connected to the network? and how do you install it?? ? Do you know a guide?
if you have received the st you are probably still in assistance, so you should contact your seller to have instructions suitable to your infrastructure.
if you do not update, you uninstall the old version and install the new one.
Alternatively, you can have multiple coexisting versions with the "multiversion" installation option.
Can you give me some tips?? then from pcs how do I install the st from the server?
st as the others install them on the local pc and not on the server, each pc will have installed the st version, only that the license that will edit will not be
on the local pc but on the server. in practice it is only the license that will be saved on the server where each post will go to read it.
so I install st normally on pcs but how do I install it on the server?
Thank you very much
Thank you very much
Good question, I have no floating licenses so I don't know if there's any physical going on the server or from local you can install the license I know with a solid edge program that runs it. ask your assistance/reseller. As the hunter said, if you got the st, you're in assistance so he calls the dealer and he'll know how to explain.
I uninstalled if to then install st, the license I gave the path on the server of the if though when start st tells me that the license is not valid, then I wonder, they gave me the st but for the license I have to call the supplier?? ? :confused::confused:
I'm sorry, but the first time I did this, he usually did another person. But I'm just the son-in-law, or the son-in-law and buy it? Sorry but I don't know anything about these things:
then, if it's the first time you do this, maybe you need some identification codes that should provide you with your seller, or that should give you the person who took care of it before you (in general the codes are associated with the company, not to individual people). Of course the seller gives you the codes if you already have a contract with them. Once you have the codes to access the site, you can follow the instructions to generate the license.
the update is not bought time by time, it is included in the annual price of the maintenance contract. If you have received the solid edgest dvd, you certainly have the right to these codes.
Okay perfect, thank you very much
