internal error opening file
nuxe
Hello.
I am desperate... I have been trying for hours to open a 3d file of autocad on which I worked for a couple of days without any problem, but strangely from today as soon as I try to open it I appear the nice written:
internal error: !saveres.cpp@437:egeneralmodelingfailure
How can I solve this? Please tell me there is a way to recover the material!
Help! ! ! ! ! ! ! ! !
welcome in the meantime, then should you tell us with which version of autocad works?
what kind of design is: architectural, mechanical or other... .
First of all, a presentation is always welcome.
However, tried with a _recover?
or try to restore .bak? (always that the backup function to the rescue has not been disabled).
Hi, Ezio.
work with autocad 2006 (I know very old!) and the design is architectural.
Anyway I solved by sending the file to a friend who managed to open it without problems, renamed it and sent it back;now it seems that everything goes well!
but the problem is to attribute to the version of autocad or to the fact that I use it on mac?
Since I use autocad on mac through parallels I have had endless grains: 3d files are very slow and unmanageable, although very light; they scatter objects and even sometimes files I can not even open them anymore.
Now my fear is that the problem is coming back again. What should I do?
x planner:I tried but I can't open the bak file....probably will be disabled the function!but I don't even know how to activate it.
...from when I use autocad on mac through parallels I had endless grains: 3d files are very slow and unmanageable, although very light. . .
bhe, operating in virtual on mac what did you expect? It's normal that management is slower.
...they spread objects and even sometimes files can't even open them anymore.
if you use autocad always, I wonder why use the mac?
...x planner:I tried but I can't open the bak file....probably will be disabled the function!but I don't even know how to activate it.
.bak don't open, they rename. where you need to rename the .bak file in .dwg extension
beautiful question....si, use autocad always but I also use many other programs like photoshop,cinema4d,vrayperc4d and on mac I have to say that I am much better!
Thanks for the information on bak, I had no idea!
