inventor - move details while using the "wine" command
jiji_akiko
Good morning to all,
Recently I started using inventor, and I noticed that while using the "wine" command I have no chance to move the components to see maybe surfaces to completely bind the particular; So I find myself every time out of the command, move the piece and reopen it.
Can someone tell me if there is a key that allows you to move while the command is active?
Thank you in advance all and good start of the day!
actually after selecting the first side or edge (cold 1), before selecting the 2nd, you can press and drag the object by moving it1694087657846.webp
as you see from the attached video, you do not even need to use the red cube option, after selecting the first part to be bound, press and drag on it to move it
Hello, Marco.
seeing the video and making various attempts, I eventually managed; I noticed that the move only works when you move the same detail where you place the first bond or vice versa.
Anyway it's fine and thank you very much for the video.
