layer
PaoloR1
a client I made a project with inventor, uses only autocad. asked me to export the .dwg with its layers. that I know is not possible. Does anyone know how to do this?
Thank you and hello.
Palo
Before making the table, you must create the idw environment with the same layers set in its dwg environment of autocad;
It is a job you have to do before and not after, otherwise you just need to rename and change all once in autocad;
but excuse the question .. what did he ask you this??
has not already given you a detailed environment or specification (engineering rules...) during the bid??
dear eugenesis, unfortunately not. I was clear from the beginning. I have inventor; project with inventor; I can export them to .dwg, but I don't have time to create your own environment. answer: no problem. So much is a equipment for a workshop machine. we do more. so we do not care to have the correct formats. But then, finished everything, here comes the manager of the workshop....... disaster.
I take advantage of your kindness. having never created an idw environment by modifying layers, where do I "create them and save them"?
if on designs are many, you can use the function within autocad that is called "conversion layer"
card manage group standard cad conversion layerconversione layer.webpor configure standard
this, if it is a native design of autocad, while in inventor you have to have a norm under the name of the customer pointing to a "default of the object"
always with the customer's name in which it attaches styles and layers with a unique name, obviously different to those of the date design.
save the idw model and that is the correct environment x that customer.
Of course, I thought I knew he didn't want to run the layers from inventor
